  • 6 Replies
  • 1578 Views
Twostepint
I have one camera that stopped recording. Everything is correct in settings just like other cameras. Thanks
@Twostepint wrote:
Did motion test and got no light. Does this mean my camera is shot ...
It might mean that.  Did you try removing the battery for a bit and then reinserting it?
6 REPLIES 6
Can you make a manual recording from that camera?
Is there a subscription for it?
Twostepint
Yes to both. All my other cameras still work, just this one stopped.
Ok.
Check the mode you are using, and make sure the rule for the camera is still there.  https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them  Also, make sure the camera is armed.
In addition, use the motion detection test, to make sure the PIR motion sensors are working properly.  https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
Twostepint
All settings were good. Did motion test and got no light. Does this mean my camera is shot or is there a fix? Thanks.
Twostepint
Removing batter fixed the problem. Thanks.
  • 6 Replies
  • 1579 Views
