Can 2 Base Stations in different states be on the same account? Do I need subscription plan?
  • 1 Reply
  • 549 Views
Timyocca
I bought a second home and want to run 3 more cameras on the same account. Can 2 base stations in different states be on the same account? Also, do I need a subscription plan for more than 5 cameras? I’ll have 8 total with 2 base stations.
If you have 8 pro 2 cameras, then you will either need to use two accounts or you will need a subscription.  If you are using some newer cameras (Ultra, Pro 3, Pro 4, Essential), then you will need a subscription in order to get cloud storage for the newer cameras.
Note you can use friend access if you go with 2 accounts.
  • 1 Reply
  • 550 Views
