I removed and reinstalled app. But it’s still red icon on the app. Please help me.
What does it mean when the battery charging icon is red? It's on an outside camera attached to a solar panel.
It means that the camera isn't charging at the moment.
That could be because
- the battery is already full
- the panel isn't getting sun
- the temp is too cold for the battery to charge
Thanks for your reply Stephen. Saturday was the first time I have seen the red icon and it was red again on Sunday. I note that it was very overcast on Saturday and Sunday. Also, I had just updated the Arlo app (Android phone) on either Friday or Saturday, so I’m guessing these may be new icons they introduced in the update.
Just to confirm, is it safe to always leave the solar panel plugged in to the camera, even when the battery is at 100%? It’s not going to ‘overcharge’ and damage the battery? I have only recently added the solar panel, and since then the battery level has remained pretty consistently at 100%.
I would have thought that a red status indication is a flag to say that the device is operating outside of design range and needs investigation.
https://community.arlo.com/t5/Arlo-Pro-2/Using-Wasserstein-solar-panel-to-charge-my-Pro-2-but-seeing...
Yes, it is safe to leave it plugged in all the time.
Choosing a red icon color for a normal status was (IMO) a poor choice on Arlo's part.
Yup, it's a new UI change that wasn't announced nor has the documentation been updated yet.
Thank you for your reply.
Totally agree, red is typically used as a warning. Thank you!
@Kaveman wrote:
Everything is still working fine, just dont know about the RED icon. Only turns red once the batteries get to 100%.
Arlo changed the UI to let you know that the battery isn't charging. So nothing is wrong (although I think they made a poor choice when they decided on a red icon for normal status). You will also see this also at night, or when it's too cold for the battery to charge.
They put out a knowledge base article on the change yesterday - https://kb.arlo.com/1179176/What-do-my-Arlo-camera-s-battery-level-icons-and-notifications-mean
