Arlo app locks
  • 10 Replies
  • 3954 Views
Smackrc51
Arlo app locks when I go into modes/garage light / click pencil to adjust sensitivity. Once I go into it it will note go out. I have to shut down app and re open. Try again same problem
10 REPLIES 10
It would be helpful if you tell what phone or device AND the OS version
Smackrc51
Arlo pro 2 .. latest version iOS
What phone ?
But anyway, do it on the web and see if it's the phone/app or the system.
https://arlo.netgear.com
Smackrc51
iPhone 7 Plus
eantonio
This is also happening on Arlo Pro 2 cameras. When I go and change the sensitivity, the app will not go back after hitting Save or Cancel. I have to quit the app and open again. This is on iOS 12.3, using iPhone XS Max. Hey Arlo, fix your app and make sure everything works before releasing it. Thanks!
ShayneS
Hi @Smackrc51
What device & OS are you using when you experience this issue?
Smackrc51
ShayneS
What version of the Arlo Mobile App are you using? Is your base station & cameras up to date on the latest version?
Smackrc51
iOS iPhone 7
ShayneS
@Smackrc51
You are running IOS 12.3?
  • 10 Replies
  • 3955 Views
