- Email to a Friend
I've had these for several months, and have loved them up until now. Yesterday I charged and reinstalled on of two of my Arlo Pro 2 cameras. Wouldn't connect.
**The only other thing I've done on my network, was update my printer IP recently on my other work PC. No changes were made, just updated the IP software side.
I've rebooted, de-batteried, reset, resync, re-add cameras. It all goes well and looks like it's connected and going to work fine. But when you hit live, it sits there trying to connect. It also does not record anything, but it will send me motion notifications. So we know it's 100% software issues here.
If I go into the activity zones in the settings, I can view video, or at least it does a current image capture just fine, so the camera itself works.
What really frustrates me here, when I do a reset, it never really resets anything. It still shows me an image from 12 hours ago when I get it all setup. It's retaining information.
What do I do? I'm not super concerned as I bought these at Costco and they'll take a return no problem. However, I would hate to have to do all that waste if I can fix it myself. I should be able to fix it myself.
Jason
- Email to a Friend
Cant connect to cameras ia laptop (mozilla and internet explorer) and android app. bad time Netgear!!
- Email to a Friend
Did you get the update with HomeKit installation? That's what screwed up my system. None of my cameras work, even though it sets up fine.
- Email to a Friend
Hey Guys,
This may be related to the Homekit setup installation hang. Did your app try and update?
- Email to a Friend
Base unit updated to new firmware and keep getting NOT ONLINE message for my base station and cameras.. Release nots says to fix going offline. Never had a problem before now they say they fixed it and NO this is the cause
- Email to a Friend
- Email to a Friend
I am having the exact same issue. I can log into account and see video feed on settings for camera but cannot see it on mobile phone and it is not detecting movement. Help.
- Email to a Friend
Same problem started on 04/19/2019
Equipment:
Arlo Base:
Model: VMB400r3
Serial: 4R03757DA567F
Firmware: 1.12.2.0_2794
Arlo Camera:
Models: H8 (Pro) & H4 (Pro2)
Firmware:
H4 1.125.13.0_31717
H8 1.092.0.19_26228
- Email to a Friend
Thanks for all the replies.
I have the app and I have also tried to connect using a browser (Safari, Chrome, IE). they all behave the same. After a minute of spinning, it comes back and says it cannot connect to Media server! I can see the camera status, for instance the batter level but I just cannot connect to any of them. Very disappointed in Arlo!
- Email to a Friend
- Email to a Friend
My app version is 2.7.7 which was released April 9. However, everything was working just fine until the day before yesterday!
- Email to a Friend
Methinks this is buggy and was a forced server push: H4 1.125.13.0_31717
Since I didn't make any changes, I cannot see how this is anything but an Arlo caused issue.
Equipment:
Arlo Base:
Model: VMB400r3
Arlo Camera:
Firmware:
H4 1.125.13.0_31717
H8 1.092.0.19_26228
- Email to a Friend
Exact same problem here in London Ontario. All equipment (base station plus 3 cameras) worked AOK then ceased normal ops as of end-of-day 2019-04-18. Removed cameras, rebooted cameras & base - no joy. NetGear, get your end into gear plz. I do not need nor want another plastic paper weight.
- Email to a Friend
I am also experiencing this problem for the last 2 days. I am trying a new base now and the firmware install is taking forever. should I wait it out? Is anyone back online yet?
- Email to a Friend
- Email to a Friend
Been on phone with technical support for over an hour. Had me do exactly what everyone else has done and still no resolution. Frustration level is increasing. My home system is fine and I can access all cameras but my office system are stuck with images from the 18th.
- Email to a Friend
Hi
I have 5 cameras Pro 2 that are both type H3 and H4 that cannot display live imagery. I am sitting in Denmark
Yours sincerely
Jesper
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
No I don’t have HomeKit. Did you mean the base station? It’s on the latest firmware 1.12.2.0-2794
- Email to a Friend
Looks like there are lot of this in the same boat. Most like a software push like many others said, this is really unacceptable. Glad i didn't throw away the box, i maybe taking these back as well. Although this is the first outage since i've owne them, better be fixed quickly.
- Email to a Friend
I have the same issue. Lost ability to connect to the cameras or receive notifications since a day or two ago. Rebooted twice, removed and reconnected cameras, fully charged batteries, strongest internet bandwidth available and still not able to get it to work. Able to set off siren, change camera settings, turn it on and off, but no live view. Hopefully a new firmware update will be released soon.
- Email to a Friend
If you have access to the camera’s video settings using the web browser, try resetting the pinch and zoom option.
