On Friday 4/19/19 we released firmware for base station models – VMB4000, VMB3500 and VMB3000. Some customers have reported seeing error messages when live streaming and issues receiving motion recordings. Due to these reports, we are rolling back this release to the previous firmware version (1.12.0.1_27940) while we investigate these issues.
If you begin experiencing one or more of these symptoms, please power cycle your base station and confirm that your firmware has reverted to v1.12.0.1_27940 – found under Device settings. To power cycle, choose the ‘restart’ option under your Device settings within the Arlo app or by unplugging and re-plugging power to your base station.
We apologize for any inconvenience caused. Please let us know if you are still experiencing these issues.
Thank you,
Arlo Team
Hub VMB3010r2 firmware 1.12.0.1_27940 Did the update today or so I thought because when I went back into my app it again popped up and said the base had an update available so for the second time i clicked on it. Now the hub shows up but my cameras just say getting status? How long does this take and is anyone else having issues? Seems like lately with Arlo, "if it'snot broken let's break it."
my arlo cameras (all 17) cannot be accessed by my app, I have 5 base stations. Everything worked until sometime betwen 4am and 5am EDT this morning. No notifications, unable to view camera.. I called support at 830 am and eventually was told several people are having similar probelms and it must be their server. They can tell my camers and base station are online. I have rebooted the base station several time from the app and by unplugging and replugging. Makes no difference.
I would like to know if the server software is being worked on and when this problem is likely to be fixed. I have used the cameras without incident for several years.
My cameras stopped recording between 3:00 - 4:00am CDT. Upon opening the app this morning, it would not met me access anything before performing a firmware update. A few minutes after starting the firmware update the app said my base station was not connected to the internet. I did the things you did and have had no success. I have three green lights on my base station. Just wanted you to know you’re not alone.
Have you rebooted the base?
I've had the same problem, so I'm glad to see it isn't just me. I've had the issue in the past where I'd have to restart the base station every couple of months so figured it was that. After trying that a few times today and still nothing, I gave up. Not sure what good a security camera system does if it randomly goes out like this. NOT VERY HELPFUL ARLO! Really disappointed in outages of what some consider a key component to their family's safety.
Update: 8:20pm CDT Looks like they just started working again!
Hi, This is Braceman. I have the same problem you have; no camera's, can't access my app, system says I have more than five camera's (only have 2), this since the latest firmware for the system (19th), I have not had pictures in my library and no geofencing but receive alerts and video's by email since a firmware update last January 5th.
Wishing you Good Luck in getting the problem corrected. Most times it seems no one really cares about fixing the problems caused by the updates but they keep pushing their products!
Not working for the Arlo Pro's as well...
I escalted this and nothing from them.. They said "engineering is reviewing"...
It has been 24 hours and some customer ARLO are not recording any motion! LIVE view does not work. I am about to throw these Arlo's in the trash and get a Ring or a Blink system. This is complete downtime for us having this issue...
As shown in the figure, the web version and the app are blank and cannot play the recording. The live function is normal, only the USB flash disk can be plugged into the computer to see the recording. I tried to log in again, reset the router, remove arlo and reconnect, but the problem still remains unresolved, Case #40815057, I found the customer service but I have not responded yet.
What is the length of the recordings you get on the USB?
Is the camera battery only or powered?
What is the record setting in the camera rule for the mode that was used?
1. Yes, but only in usb can see, I tried to cancel the usb local storage, only use the cloud storage, but also can not play
2. The recording length is determined by Arlo himself, and there are tens of seconds and a minute or two.
3.battery only
4. The first mode, motion and audio detection is turned on
I have been using arlo for a few months, and the fault has only appeared in the last week.
I noticed in the Arlo Pro section of the forum that others have a similar issue an that this could be a arlo server or firewall problem.
I tried turning off the firewall of the router, but it was still useless.
one of my cameras arlo pro 2 stopped a motion detection. It detects only by audio.
I did not change anything in settings.
I can watch it live, take snaphot and record video manually.
The camera works well except the detection.
any help appreciated
Maybe try resetting the pinch and zoom feature in the camera video settings and staying as full screen.
Delete any activity zones if implemented.
Delete any rules that use the camera and re-add them to see if the issue gets resolved. I have no evidence that this will fix it but might be worth a try.
still not work
This is likely to be isolated to one of Arlo’s servers and why we all don’t get the issue. Not much comfort I imagine.
Can anyone else help out?
No,the problem is still unresolved
Are you using app ? If so, try on a browser at https://arlo.netgear.com
Also, what is your upload speed?
you are not the only one that has this problem. mine started yesterday around 4 am
