On my opening screen it used to show previous camera views when I first started it up. Now it shows no camera views unless I click on a camera run triangle button.
I was using MS Edge as a browser, and when I looked on the Arlo help site it recommended Chrome. I ran it on Chrome and worked out just fine. Thanks.
Have you rebooted the phone and reinstalled the app?
This is happening on my laptop not on my phone.
Are you seeing a gray screen on web page? I get it once and a while in the last month on several browsers for last month. It is only once and a while. Cleared the cache but still the same but might be worth a try. Like you said it does reset when I press the play button for live view.
I changed browsers and it started to operate normally. I was using Chrome that used to work fine for a few years, but started acting up in the past couple of weeks. Started it up on MS Edge and it appears ok.
Now it is doing this when I play any video. When I download it and play, it does not do this. See the video link. https://youtu.be/F82vzG_RBJg
HI @AllUsedUp
Please contact the Support Team to further investigate this issue with your recorded videos. You will find several options for contacting support in the provided link. Arlo Tech Support
