Arlo Pro 2 and Doorbell hardwired
  • 30 Replies
  • 1656 Views
stribor45
Hi everyone,
Recently my free cloud recording storage expired so I tried to set up local recording by inserting USB flash drives into my HUB (VMB4000r3). So after some time I wanted to try to read these USBs but Windows 10 wont see them at all. Wehn I look at the disk management i can see drives there and since I cant access anything on these drives since Windows doesnt see it in file explorer I wanted to format them using disk management but error keeps showing with error "system canot find the file specified) . Did anyone have  these issues?
30 REPLIES 30
Dannybear
Question to ask is if you ejected the USB device using the arlo app before removing it from the base station.
There is a format function in the arlo app under the base station settings if that is a help.
stribor45
Definitly did eject first
Could just be a bad drive - have you tried a different one?
stribor45
yes. I had two usb flash drives both healthy and both bricked now after I tried them on the hub. Both time I used eject function before removing them from the hub
You can use the drive manufacturer's health utility, if one exists, to see if you can resurrect them. In W10 disk management, can you delete the partitions so they're bare and then use them?
stribor45
I can see them in disk management in  Windows 10 but I cant use them and cant format. I cant see them in file explorer either
How about selecting it and removing partitions?
stribor45
when you say removing partitions what do you mean by that?
Any drive must be partitioned before formatting. You can break it into multiple partitions or just one. If you select the drive you should be able to right-click and choose to remove the partition (there may be more than one so remove them all). If you can, remove and then recreate a new partition for the whole drive. Then format it again.
stribor45
Can you share exact steps on how you would this as I am not quite sure I understand. As of now only way I can see the drives are by pluging it into USB port and opening disk management from within Windows 10 OS.
Yes, this is done in W10 in Disk Management. If the drive isn't dead you should be able to do all this when using the computer.
stribor45
Can't see the image until approved but you can use the paperclip icon below the text box to attach it so we can see it immediately.
stribor45
see attached
Use Delete Volume to get rid of the partition.
stribor45
Should I go thru the wizard to create new volume?
That should be fine but you may need to format the drive in your base to get it to work with Arlo since W10 really doesn't want to allow the use of FAT32 - it'll likely give you a choice of exFAT or others but not FAT32. You just want to use a basic drive, nothing fancy.
stribor45
ok I will try that and let you. What file system should I use?
stribor45
that didnt work for me but after multiple try of using diskpart command line tool i was able to clean it and than format it using disk management.  Once I put this USB back into my hub should I format it using Arlo tool?
Yes.
stribor45
So I  put the drive back into the hub...
  1. Formatted it
  2. Arlo didnt report any errors beside "ready"
  3. I can in hub local settings that some storage has been taken by the videos
  4. I ejected USB using arlo app before I  unplugged it from the unit
  5. Instered it into port on my Windows 10 machine
  6. Drive is not seen at all by the file explored
  7. It is seen by the disk managements (see image)
stribor45
sorry attached wrong image. this is the image...
Dannybear
Have you tried inserting the drive into a different USB port of the pc?
There are lots of reasons for what you’re getting. E.g.
If the drive letter of your USB drive is the same as one of the drive letters of your computer's hard disk partition, you won't be able to see it in Windows File Explorer. In this case, you need to assign a new drive letter to your USB drive.
stribor45
Yes I did try different ports and l drive letter is not c which is the letter assigned to my hard drive
  • 30 Replies
  • 1657 Views
