  • 2 Replies
  • 34370 Views
MikaelD
Hello,
I am already equipped with a Synology system with Surveillance Station and I am thinking about buying a Arlo Pro 2 EcoSystem. Will it be compatible?
Will I be able to use Surveillance Station system to manage the recordings?
Br,
steve_t
Master Master
I believe you'll need ONVIF compliant cameras. Arlo do have an ONVIF system but it's based on the Arlo HD cameras so I wouldn't go down that road
st_shaw
Master Master
Synology will work with generic cameras that support RTSP or ONVIF and can natively support many cameras.
Arlo Pro2 is a closed system and you cannot use it with Synology Surveillance Station.
  • 2 Replies
  • 34371 Views
