troubleshooting issue - loosing Arlo intermittently
If you have properly set up the base with a USB stick or hd AND internet goes out, it should still record to the USB backup....the files will appear there only and not get transferred to the cloud when internet comes back
Hi Kathy,
I hadn't replied to your private emails yet as I have been extremely busy the past couple of days. Be sure to read the instructions carefully on how to dismount the memory drive in the app. You will have to insert it into a computer to view it. Don't know if you installed the Smartthings hub yet, but unlike Arlo, Smartthings notifies you if the hub goes offline. Since there are batteries in the Smartthings hub, you should be able to know if it is a power loss or internet failure. I'm guessing it is probably the latter.
Also, if you have installed your Lorex system, you should be able to look at the DVR and see if there are gaps in the recordings as that system doesn't need the internet to record.
Brian
