We have 3 cameras in our system and an amber warning triangle that keeps inflating and contracting has appeared in the bottom right corner of one of the cameras. The firmware is up to date but I can't find anything online to let me know what's wrong. Any tips would be greatly appreciated. Thank you.
I tried the 2 way speaking and it doesn't not work on the iOS app.
The Website works.
But the app does not.
I tried to toggle off then on the microphone permission. It worked once but sadly stopped working after that.
Someone from Netgear needs to read this thread since the problem is effecting so many people.
Amber triangle disappeared after uninstalling and then re-installing the app.
I’m having the same issue.
I just spoke to Netgear customer service and they stated that there is a bug in the app and they are aware of the problem and working on a fix.
It appears that if you delete the app and then download it again it works..
But the two way speaking still isn’t working .and yes the yes the mic settings are on.
As mentioned above, this icon will display if you have CVR or Activity Zones enabled on your Pro 2 while the camera is not plugged in. The purpose of the icon is to indicate that these features will not work unless your camera is plugged in.
I feel like Arlo has updated us all with a bug. I have never had an issue in the past and now suddenly we all have the same issue. I have 4 cameras and it is only happening on 1, (the one I recently brought in to charge). I do not use CVR and I do not plug in. It only shows on my app and not on my computer when I view the devices. My camera still seems to be working fine just has this orangle warniing icon.
The best way to get these software releases improved is to give the Arlo app bad reviews in the App Store. Consumers need to know about the problems they will experience with Netgear products.
Reinstalling the app has nothing to do with how the system operates. Is the running man for the camera gray (disarmed) or black (armed)? Is it possible you went into Modes and changed something during this process? If not, power cycling the base may well set things straight.
When will the above complaints be resolved as I’m still having the same issue after you sent out the most recent update?
It can be risky but you ca restart the base remotely. It would be good if you also have someone who has acces to power cycle the base, just in case.
https://www.reddit.com/r/arlo/comments/8datg6/arlo_push_to_talk_not_working/?st=JG73CXCI&sh=d34f1955
