I was so happy when Netgear finally solved the issue with the persistant notification "Geofencing is enabled". Now, we can just block this message from appearing without impacting other notifications from Arlo that we still need. Nevertheless, since then I noticed that the Arlo App is heavily draining my phones battery as long as geofencing is enabled.
Even if the app is running in the background and is not actively being used (means not checking notifications or watch recordings) it drains up to 20% of my phones battery in just 4 hours. This cannot be normal. After switching to schedule mode, the battery drain stops. It is clearly related to geofencing mode.
Phones tested: OnePlus 5 and OnePlus 6 (same issue)
Android Version: 9
It turns off but not on!
How Hard can it be?
I'm thinking of selling my five arlo pro 2 and buying something else.
Tip someone?
I am seriously contemplating switching to NEST cameras. Seems a much serious alternative....
I've given up on geofencing. The schedule has to be enough, now. Will not buy any other Arlo products anymore. That is for sure.
Same here. Folks, the only reason they have these forums is so users can help other users and all their problems stay here. It keeps users away from social media. If you really want answers don't post here. Just post on social media. Go tag them on Twitter, Facebook etc. At least others thinking about buying Arlo products will see the problems and not purchase this ***p.
It continuously record to the cloud, resulting in VERY heavy data use.
A thing to consider, if you do not have unlimited data 😉
PS. I too have battery drain problems, on my Huawei P30 Pro, with geofencing enabled.
Still experiencing signaificant battery drain with geofencing. Working well but almost unusable at the current battery drain level.
Also still can't swipe away geofencing enabled notification, which makes it so I can't swipe away the other 35 motion deteceted notifications...
I am also having the battery drain issue on my Pixel 3XL, has there been any comment since the new update and still draining batteries?
Android App also drains battery on my OnePlus 3 with Android 9.
It also takes long time to recognize I entered into the "home" zone, I need to kill the application and restart to force the recognition of the "Home mode".
10 hours active time for a day, Arlo please did this battery drain issue in the new app.
New User here - I noticed a similar problem with high battery usage - Samsung Galaxy S9 and Geofencing.
Could we get a fix, please.
version 2.9.2_25930
I'm having the same problem, using a Oneplus 3T running LineageOS 16.
My phone has been sitting idle on my desk for most of the last 23 hours, in that time the Arlo app has used up 53% of the battery with 23h active time. I do have geofencing enabled, but still this power usage is insane. As a comparison I have tasker running which has the same active time but only 2% battery usage.
Edit: Running version 2.9.2_26040 of the app
