Netgear,
I'm running 12 Arlo Pro 2 cameras and have some input that I'll send to your support directly as well but want to share here in case you're reading... The Arlo Pro was a great system and I was hoping the Arlo Pro 2 would be even better, but I'm noticing some shortcomings...
Please remove the not plugged in warning for every camera in the Arlo app. Comes up every time I launch the app and I have to click "Ok, I got it" on every camera, just annoying when you want to see the thumbnail preview. Put the info message elsewhere like when a user tries to enable the CVR or video zones.
Nightvision - On battery, the nightvision on the Arlo Pro 2 vs. the Arlo Pro is not good... Haven't tried on power, but don't plan to use power. I'm really disappointed in the quality of the nightvision overall. There are a lot of dark black areas and the picture just isn't lit up as crisp with the Pro 2 vs. the Pro. Also, when motion is detected, some cameras record pitch black for a second or so and then as the IRs illuminate the picture the nightvision starts to show up. Never had this with the Pro version, worked like a champ. I hope this can be resolved in a firmware release so that I don't have to buy all new cameras...
For those experiencing this issue, are you using an Arlo skin on the camera when you are testing Night Vision? If so, does the skin have a visor or no visor and is it a third party or Arlo branded skin?
JamesC wrote:For those experiencing this issue, are you using an Arlo skin on the camera when you are testing Night Vision? If so, does the skin have a visor or no visor and is it a third party or Arlo branded skin?
James,
No skins on all 12 of my Pro 2s that are seeing the degraded night vision quality over the Pro.
No skins for me either
The quality is not only grainy, but dark, little contrast. All it takes is a bit of light and the quality does go up
Rick
I use the Arlo branded skins and I had really bad washout/IR issues on my Arlo Pro 2. I knew the skins were causing the problems because I can actually see the skin producing a "fisheye" effect on the top corners of the cam (looks like a new Arlo branded skin needs to be made for the Pro 2), so I just pulled the skin back a little more so the hood can clear the IRs. Seems to work better, but the image is still washed out and is still not as good as the Arlo Pro.
I've escalated the feedback on this topic to the product management team. The engineering team is currently investigating the concerns being discussed here and I will provide an update as soon as I have more information.
JamesC wrote:I've escalated the feedback on this topic to the product management team. The engineering team is currently investigating the concerns being discussed here and I will provide an update as soon as I have more information.
Thanks James, looking forward to a prompt resolution. Let me know how I can help...
Coincidence...I think not.
Same issues.... Rediculous.. These are far worse than the Arlo Pro nightvision
There have been deleted posts showing camera USB ports and batteries lightly burned, enough to stop the camera from working. Not a whole lot, but a few. Also some outdoor adaptors have lightly melted at the usb connection point while plugged in. Could it be from moisture getting into the connection, who knows. Not sure if I can believe what Arlo says is the problem. Arlo mentioned a replacement is coming within the next few “weeks”... and that has me confused....
I’m the meantime, they probably have their production at full speed.
im really hoping this is software based and can be fixed with a firmware update. IF they have actually found a hardward flaw, then they need to allow replacements directly from them for the defective units. The daytime video is really good, noticable to me over the original pros, so i hope they can fix this night time issue.
Lawenforcer wrote:im really hoping this is software based and can be fixed with a firmware update. IF they have actually found a hardward flaw, then they need to allow replacements directly from them for the defective units. The daytime video is really good, noticable to me over the original pros, so i hope they can fix this night time issue.
I'm really hoping the same...Especially that Netgear makes it right with current Pro 2 customers if there is a hardware flaw.
Just posting an update on what I know from Netgear...
JamesC has been working with me on trying some troubleshooting items. He's been great so far. The last communication was this morning. Netgear Engineering wanted pictures of how my cams were mounted. I sent those pictures and JamesC replied saying the issues being reported are being investigated as a top priority right now for the Engineering team.
I'm just sharing to let everyone know there is some progress in the background going on...
Hopefully a solution soon!
Also, I had a curiousity question for those with washed out nightvision... How many of you are seeing the "ring" around your picture? For those that are, is that just how it looked from day 1 or did you change settings to get that?
I was able to resolve my night vision issue by removing the Arlo skin.
