  • 7 Replies
  • 3083 Views
BClemmons
I have an Arlo SmartHub base station and three Pro2 cameras at home, and would like to add cameras at our vacation condo in another city.  Do I need a new base station, or can I add them to the existing system?
@BClemmons wrote:
If I had a 7-day cloud storage trial, it has long since expired.
7-day cloud storage was not a trial, so it did not expire.  It is a feature that Arlo will discontinue at the end of this year for the Pro 2.  1 April 2023 for the older Pro.
@BClemmons wrote:
The VMB number is 4500.
Which supports local storage, but you need to eject the drive and connect it to a PC to examine it.  All recordings you see in the app and my.arlo.com are stored in the cloud.
Access to local storage would require a smarthub (VMB4540 or VMB5000).
Limitations of direct access are:
  • recordings only available in the app (not the browser)
  • recordings only available from the primary account (no shared "friend" access)
  • no ability to make manual recordings or save snapshots
  • no thumbnails - videos have to be downloaded to the phone to see anything.
  • remote access requires router settings changes that some find difficult (and can't be done at all with some internet service providers).
You could try direct access for the other location (getting a VMB4540 base) and then go with the subscription for that location if you find that inadequate.  Then decide at the end of the year whether you want to upgrade the VMB4500 to a smarthub, or whether you want a second subscription for your primary residence.
7 REPLIES 7
You'd either need a base at the vacation home, or you'd need cameras that can directly connect to your condo's wifi.  For instance, Pro 4, Pro 5s, and Essential cameras can connect to your home wifi.
I'd avoid cameras on the EoL list.
Keep in mind that you will need a subscription for cloud storage.  If the cameras are set up in two different locations (part of the new UI "Feed" experience), you will need one subscription for each location.
BClemmons
We do have Wifi at the vacation home.  I'm not sure why I'd need cloud storage.  I don't have that now.
Thanks.
Wrong - you do.  All Pro 2 cameras came with free 7-days of cloud storage
What base station model do you have?  There's a VMB label on the base.
BClemmons
The VMB number is 4500.  If I had a 7-day cloud storage trial, it has long since expired.  I bought the Arlo system 3 or 4 years ago, but the base unit quit working last year so I replaced it with this one.  Thanks for any help.
BClemmons
Thanks for taking the time to provide such detailed responses.  I really appreciate it.
FYI, Arlo just changed this.  EoL for the Pro 2 is now 1 January 2025, and they will continue 7-day cloud storage on all the legacy cameras (indefinitely).
  • 7 Replies
  • 3084 Views
