Login issue - verification code is not received
Hello, after not using the system for some time, I am being asked to login again if I try to use the iOS app, or at my.arlo.com.
I then see a message:
Verify your identity.
Please enter the verification code that was sent to 10****@mail.com
The problem is that no code is received. I have checked the spam folder, and tried multiple times. How to resolve this?
Here's a screenshot for reference.
https://share.zight.com/L1uEXABZ
thanks
@JamesC I see you helped someone with a similar issue, any chance you can give me a hand? Thanks 🙂
10Pow,
If you select "Try another verification method" are you able to select SMS? This will send a text to your mobile device to authenticate.
thanks for getting back to me. unfortunately no. Receiving the code is the only option.
What options do you see if you select "Try another verifications method" ? Are you able to provide a screenshot?
If I select "Try Another Verification Method" it just gives me the option of choosing email. See screenshot here (for some reason when I insert an image in the post nothing appears) https://share.zight.com/yAueJwN0
Then when I choose email, I don't receive the verification code. Conversely, if I choose Forgot Password, I do receive an email to reset it - see here: https://share.zight.com/04un6lBv
I've escalated the details you've provided here and the development team is investigating your account. I will provide an update as soon as I have more information available to share.
We are having this exact issue, has there been any resolution? If so please let us know. Thanks!
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
