- English
- Services
- Arlo Home Security System
- Re: Keypad Constantly Losing Connection (Keypad Of...
My keypad recently started losing connection (Keypad Offline). It is happening 9-10 times per day and throughout the night. Has anyone else seen this behavior and/or found a fix for it? I have moved it closer to the router and tested it from various electrical plugs. Super frustrating.
Note: The system is behind a Firewalla Gold firewall.
Can you please try to do a reset on the keypad and see if it changes the behavior you are seeing?
https://kb.arlo.com/000063161/How-do-I-factory-reset-the-Arlo-Wire-Free-Keypad
The link you provided is not working.
It opens when I click on it.
You can copy and paste it into a browser as well if it will not open for you.
I will try the reset tonight and report back. Thanks
I performed the reset on the key pad. Added all my devices back. It is still disconnecting . 'Key Pad Offline' - Please make sure its powered on and connected to the internet. This is getting very frustrating.
Is the keypad under the same email address as the cameras? I am not seeing a keypad on the account. Can you please dm me the serial number that is on the keypad? You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
PM sent.
I got your message, thank you for providing that information. I have reached out to support, they will be in contact with you as soon as possible.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
