  • 9 Replies
  • 3221 Views
Dimbulb11
My keypad recently started losing connection (Keypad Offline).  It is happening 9-10 times per day and throughout the night.  Has anyone else seen this behavior and/or found a fix for it?  I have moved it closer to the router and tested it from various electrical plugs.  Super frustrating.
Note:  The system is behind a Firewalla Gold firewall.
9 REPLIES 9
BrookeN
Can you please try to do a reset on the keypad and see if it changes the behavior you are seeing?
https://kb.arlo.com/000063161/How-do-I-factory-reset-the-Arlo-Wire-Free-Keypad
Dimbulb11
The link you provided is not working.
It opens when I click on it.
BrookeN
You can copy and paste it into a browser as well if it will not open for you.
Dimbulb11
I will try the reset tonight and report back.  Thanks
Dimbulb11
I performed the reset on the key pad.  Added all my devices back.  It is still disconnecting .  'Key Pad Offline' - Please make sure its powered on and connected to the internet.  This is getting very frustrating.
BrookeN
Is the keypad under the same email address as the cameras? I am not seeing a keypad on the account. Can you please dm me the serial number that is on the keypad? You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Dimbulb11
PM sent.
BrookeN
I got your message, thank you for providing that information. I have reached out to support, they will be in contact with you as soon as possible.
