  • 11 Replies
  • 5030 Views
ArloGoVML4030
I got a loud howling noise in the background on every recording can I get rid of it?
https://arlo.netgear.com/hmsweb/users/library/share/link/5F148EF3D16142F5_201903
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
11 REPLIES 11
Cranked the volume all the way up and hear very little. Have you tried a different device to view/listen to the videos? Download and view them locally, too.
ArloGoVML4030
@jguerdat It's the same noice when I download it
ShayneS
Hi @ArloGoVML4030
  Have you tried contacting customer support regarding this issue? I have attached the link here for you -  Arlo Tech Support
ArloGoVML4030
I had the camera replaced and the new camera has the same problem. Arlo Tech says that has to do with units that have sim cards and data traffic. Ive tried different sim cards and different mobile providers and locations but the problem wont go away.
ShayneS
Hi @ArloGoVML4030
I would suggest contacting support again and letting them know your newer unit has the same result as the previous.
ArloGoVML4030
They know I replaced it. They didn't have any solution. I also have problems with the battery draining, 50 percent after a week. I have good 3g connection. They have send me a new battery
ArloGoVML4030
The problems remains, draining the new battery too. And loud backround noice. Arlos Tech has no solution, Anyone with the same problems?
ShayneS
Hi @ArloGoVML4030
I have escalated this issue for you an customer support will be reaching out to you soon.
ArloGoVML4030
I've installed the original Netgear solar panel charger and i get I failure message that the charger is incompatible and the power is dropping even though it's sunny and 22 degrees Celsius here
ArloGoVML4030
I've rebooted the camera and pulled the cable out of the camera but that didn't help
ShayneS
@ArloGoVML4030
Have you been in contact with customer support?
  • 11 Replies
  • 5031 Views
