Loud Background Noise
https://arlo.netgear.com/hmsweb/users/library/share/link/5F148EF3D16142F5_201903
Cranked the volume all the way up and hear very little. Have you tried a different device to view/listen to the videos? Download and view them locally, too.
@jguerdat It's the same noice when I download it
I had the camera replaced and the new camera has the same problem. Arlo Tech says that has to do with units that have sim cards and data traffic. Ive tried different sim cards and different mobile providers and locations but the problem wont go away.
I would suggest contacting support again and letting them know your newer unit has the same result as the previous.
The problems remains, draining the new battery too. And loud backround noice. Arlos Tech has no solution, Anyone with the same problems?
I have escalated this issue for you an customer support will be reaching out to you soon.
Modes et règles
