  • 94 Replies
  • 58308 Views
  • 6 Likes
  • 14 In Conversation
er-minio
I'm not sure if this is really a camera problem or and app/system issue.
Goefencing for my Arlo Go camera stopped working recently.
I tried resetting the geofencing zone, changing sizes, to no avail.
The phone has location sharing, background refresh, etc. etc.
There is another user, same, all settings are good on the other phone.
Geofencing has been working for years at this location, no big changes done apart from switching the SIM in the Arlo Go Camera at the beginning of August (V-SIM shut down) and Geofencing worked ok after that.
I have to manually arm/disarm the camera and, a couple of days ago, even disarming the camera wouldn't do anything as I would get movement notification (and movie recordings) despite the camera being set as "disarmed".
Is there some software issue? Update needed?
94 REPLIES 94
BrookeN
Can you provide more details on how you are wanting to set up your Geofencing? I would be more than happy to help.
Neaves
In keen to see a real resolution for this issue as we have had problems ever since the new app was rammed down our throats. Constant issues with geofence not working. Done everything and it starts working for a short time, then starts going faulty again. Activates when only one person leaves most of the time, or not at all. Never disarms on return. I’ve given up and created an applet on IFTTT that does exactly what I need it to do and it works without fail. Really shouldn’t have to spend the extra money for a function that is “supported” natively.
Just tell us straight that there’s a problem with the app and it needs fixing. Also admit your developers probably need more training. The fact is most of us on this thread (most of your customers more likely) are having similar problems and only since the new app was released.
alex_loo
Virtuoso
Virtuoso
Can you share how you use IFTTT?  I'd like to see if there is any way to trigger Google Home from IFTTT, on a geofencing in/out event.
Alex
Neaves
Of course.
At least one user will need a paid account to get the applet working as needed.
You need to create a group in Group Locations trigger that contains the people/devices. This will be the trigger using geofencing.
Then the action will be to change your Arlo device status. If you are using a base station to connect all your cameras, the base station will be the device to reference.
alex_loo
Virtuoso
Virtuoso
@Neaves wrote:
Of course.
thanks.  A few questions:
1. can this ifttt group location trigger trigger off, EVERY TIME one of the devices returns the defined location (irrespective of where the remaining devices are)
2. in general, when there is an IFTTT trigger fired off, how do you send a trigger to Google Home?  (so I can do something else there)
many thanks.
Alex
Neaves
1. Yes, you set the tiles how you want. Mine is arm when last person leaves and disarm when first person enters. Works every time.
2. Google Home is not an action in IFTTT and can’t be used. You need to link direct to Arlo or any other server you have in mind.
alex_loo
Virtuoso
Virtuoso
Hi @Neaves , thanks for the reply!
can you trigger on ALL of the following? :
  • when first person enters (that's what you have done)
  • when second person enters
  • when third person enters
  • when last person enters
Above is exactly what I am looking for.
I have already linked up ARLO to within Google Home but then the issue is the ARLO device, as a Google Home Automation starter, doesn't work at all.  I am feeling this is another bug with ARLO (tagging @JamesC and @BrookeN )
So in trying to achieve above, I have been exploring turning an IFTTT device ON/OFF and having it monitored by Home Automation (as a starter trigger).  However, I have not been able to find such device (well, I prefer it cheap too).  Are you aware of any such device?
Alex
Neaves
The starters available are currently limited to any member, first member or last member. So in your case, you could use any member as it would trigger every time member enters or exits, no matter if there first, third, last, etc.
Arlo cameras are not available devices in Google Home automation triggers for movement detection if that’s what you’re looking for. If you need that, you’ll need to get Google Nest cameras.
alex_loo
Virtuoso
Virtuoso
Just to confirm above is regarding ITFFF (not Google Home Automation)?  Meaning ITFFF:
  • can have individual member triggering, every time he enters or exits (no matter if he is first or not)
  • can be configured for "group location trigger", which only triggers on first entry and last exit
Is my understanding correct?  If so, that would be exciting news for me.
Alex
alex_loo
Virtuoso
Virtuoso
(trigger by camera movement) That's NOT what I am looking for.  I just want Google Home Automation to ARLO modes for me --- not just the basic last exit and first entry scenarios, but also:
  • first, second, ... last entry of ANY member
Apparently GHA does not support this, that's why I am exploring other options, say via IFTTT.
Alex
Neaves
Correct. This is using IFTTT logic. Just to clarify, the group location triggers are attached.
Neaves
Correct. GHA does not support this so IFTTT is required until Arlo employs competent developers.
alex_loo
Virtuoso
Virtuoso
picture not showing .... help! @StephenB @JamesC @BrookeN
Alex
Neaves
Triggers are:
  • Any member enters or exits an area
  • Last member enters or exits an area
  • First member enters or exits an area
  • Any member enters an area
  • Any member exits an area
  • Last member enters an area
  • Last member exits an area
  • First member enters an area
  • First member exits an area
alex_loo
Virtuoso
Virtuoso
So they are pretty complete there.  Thanks for the info.
Since I don't have PRO subscription, I can only do "me entering an area anytime", and run the same login at all the member devices.  See mine below:
As for "all member away", I think I can use Google Home Automation to achieve that.  No need for IFTTT pro.
But thanks again for the update.
Alex
ps: @StephenB do you mind enabling the pic please
Just did.
Neaves
Yes, you need a pro account which is cheap anyway. And no, you can’t use Google Home Automations at all to arm and disarm Arlo cameras.
alex_loo
Virtuoso
Virtuoso
actually for arming, you can.  I have been successfully switching my ARLO to ARM HOME and ARM AWAY --- from my Google Home Automation.
as for disarming (STANDBY), you are correct this is not possible with Google Home Automation --- an intentional move by Google, probably trying to play safe and get rid of any risk/responsibility, in case of "wrong" STANDBY causing troubles with customers, and the risk of follow-up lawsuit.
That's why at the moment, I am using IFTTT to do the actual work to switch arlo to STANDBY.  If I want, I can still use Google Home Automation to tell IFTTT to do that, via an IFTTT routine that is made available to GHA.
Alex
alex_loo
Virtuoso
Virtuoso
@Neaves , a question for you.
for "Any member enters an area", is there any way to do the following tasks:
  • Disarm ARLO
  • Wait for 15 minutes
  • If ARLO stays at disarm/standby, then switch to arm home
Many thanks
Alex
alex_loo
Virtuoso
Virtuoso
  • Disarm ARLO
Many thanks
Alex
hi @Neaves , just to share that I have successfully achieved above, purely using google home automation and free version of IFTTT!  (oh plus 1 physical smart switch too)
Alex
