  • 2 Replies
  • 1733 Views
Jess2604
Hi my arlo go camera appears to be offline on my app, I have done everything to try and fix it, iv logged in and out of my app, took the battery out, reinserted my SIM card, everything and it’s still offline, I then restated my account and now it won’t sync my camera to set it up again it’s saying th QR code isn’t right and won’t scan the code or anything.. really don’t no how to fix this now... I don’t no why is isn’t working either, is it the battery or SIM card?? Thank you Jess
Jess2604
Hi yes I sorted it, I rang Vodafone and they put me through to the V-sim team, I had to google how do I put my arlo go to factory settings and then it had a QR code to scan, then it connected back to my sim then when I scanned my QR code and re set my arlo go up to my phone on the app. Thank you
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Jess2604
  • 2 Replies
  • 1734 Views
