I have 5 Arlo go cameras and have just bought another new one. I've put a Vodafone V sim card in and all went well until I came to look at the new camera on the app. The message said 'This device is inactive. A paid Arlo Smart subscription is required to activate the device.' I've never done this before I've used V Sims. Any help would be appreciated. Thank you
@moprabbit wrote:
Thank you for your reply Jguerdat. Just got in a bit of a mess! I've created a new email address and then logged in to my original arlo account. Clicked on 'create account' and created a new account, but then I couldn't find my 5 original cameras.
The simplest solution would have been to add your new camera to your existing account and purchase a subscription for it.
If you want to use two accounts for some reason, you can set up friend access so you can see all cameras from both accounts. Some functions require you to use the primary login, but for normal monitoring the friend access is fine. https://kb.arlo.com/000039106/How-can-multiple-people-access-the-same-Arlo-account
The free plan is for only 5 cameras - adding a 6th means you either need a subscription or set the new camera up on a new account using a second email address. You can then use Settings, Grant Access so all cameras show up in one login.
Modes et règles
