Loose connection usb port not charging
  • 1 Reply
  • 1016 Views
ArloGoVML4030
Having problems to make the solar panel and charger to work. Only works from time to time the USB port has loose connection. Any way to fix this? Seems hard or impossible to find replacement usb port to fit arlo go
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
ShayneS
HI @ArloGoVML4030
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 1 Reply
  • 1017 Views
