Arlo Go issues with Settings Icon since last update
  • 15 Replies
  • 6445 Views
moprabbit
2 days ago I found I had difficulty using the settings icon on my arlo go cameras. The problem was very random, sometimes 1 camera would be ok then next time I put the cameras on the camera that did work, wouldn't and one that didn't work, would work. I've reported the issue to Arlo support but I wondered if anyone else had a problem. I've also just got another arlo go camera and I can't get that working. Wondered if that could be related. Thank you
ShayneS
HI @moprabbit
This issue should now be resolved. Please update to the latest version of the Arlo Mobile App v3.2
Thank you!
15 REPLIES 15
ShayneS
Hi @moprabbit
Please make sure to have the latest version of the Arlo mobile app installed on your device. You can find the latest FW versions here
ArloGoVML4030
I have the exact problem. Android mobile
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
moprabbit
Sorry to hear that. I should report it to Arlo support then they will know others are having the same issues. I've reported it and have a case number. They've said they will try to get it sorted out.
moprabbit
Thank you for your reply. I have downloaded the newest app but the problem still persists.
ShayneS
Can you please provide a little more detail regarding the issue you are experiencing?
Thank you
moprabbit
Hi ShayneS, when I log in to my 3 cameras and go to 'settings' then to 'my devices' instead of seeing all the settings there is sometimes just a picture of a base station and none of the settings show. Sometimes this shows on all 3 cameras, sometimes just on one and the others are all normal. Next time I log in, it will be different, 2 cameras might show the picture of the base station and the third shows the settings. Every time I log in, it's different. That's the problem.
ShayneS
Thanks for the detailed info. Is it possible to provide a screenshot when this issue occurs. Thank you
moprabbit
I'll try to attach the picture of what shows when the camera settings don't appear. Hope this is the correct one! It just looks like a little white box.
ShayneS
Hi @moprabbit
ShayneS
Hi,
Is this issue occurring on Android & iOS? does it happen on the web portal as well?
moprabbit
Hi Shayne, the issue only happens on the Android devices. On my computer I can access the camera settings.
Regards
ShayneS
Thank you for providing this info, I will provide an update as soon as possible.
ShayneS
HI @moprabbit
Thank you!
moprabbit
Hi Shayne,
The problem now seems to be resolved. I can access the settings now. So that's good. Thank you for your reply and taking the time to look into the matter. Kind regards Ann
ShayneS
@moprabbit
That is great news!
Thanks for letting me know.
  • 15 Replies
  • 6446 Views
