I have 8 Arlo Go cameras in various positions around a field. Two of them are always going offline. I've changed their positions, cleaned the sim cards, done factory resets, put them in the same positions as other cameras but still they go offline. Any suggestions would be most appreciated. Thank you.
Best answers
An update is now starting to roll out for Arlo Go users who experienced offline issues with their camera. We expect it to reach all Arlo Go cameras in the coming week. Users may need to reboot (remove/re-insert the battery) and recharge the battery to receive the update, if your camera is already back online, no further interaction is necessary.
Additionally, we would like to clarify that this issue was not related to the 3G shutdown that has occurred on some carrier networks.Thanks for your patience and understanding. We'll continue to closely monitor your feedback to ensure your issue has been resolved.
Team Arlo -
Arlo is actively working with carriers to identify all the variables that could be contributing to this issue. It is a high priority for Arlo.
Thank you for the feedback & continued patience while we work to resolve this issue. We are actively working with our partner at AT&T to troubleshoot the situation.
Thanks, Scott. Absolutely, let's make sure that we have our cases open. I did order two new sim cards as recommended by the team. Figured it won't hurt to do that since the cards are something like 5 years old. I'll hold on as they work on this. Also thanks for the email address, it's quite the game with the automated chat to finally get to a person!
I do hope they get this figured out.
However, I plan to try a T-Mobile sim in my camera and hope it works.
AT&T charges $20/month
With the small amount of data I use, T-Mobile is charging $5/month
Assuming that the Reolink on T-Mobile continues working (Haven't found it to be offline yet), If the T-Mobile sim in Arlo doesn't work, I'll likely just cancel the AT&T plan and move on.
Why throw away $15/month for substandard service?
Let us know if the t-mobile sim card works on it? Interesting. I tried to unlock the cameras via AT&T and it would not work. Maybe they are unlocked and it will work.
I don't understand why Arlo cant step up and get his fixed or let the customer know they don't have a fix. It has gone on for almost 2 months and no help. I think a class action claim might be the best option at this point.
I bought a T-Mobile sim card - Figured all that was at risk was $16.
For those of you considering this, save your $16
T-MOBILE SIM DOES NOT WORK IN AT&T ARLO Go.
I previously tried the "Unlock Procedure" thru the AT&T website and it said it was not an AT&T device. I figured it must not be locked. No such luck.
That is really too bad. I had high hopes. I see no reason to keep going down this, very frustrating path.
To anyone at Arlo that is willing to listen: If you can make this camera work with a T-Mobile Sim card, I'll keep it. If not, I'll be turning it off and moving on to Reolink.
I'll give this about two more weeks and then I'm moving on. As I mentioned earlier, the $15/month difference in service cost will fully pay for a new Reolink camera in 16 months.
From tech support:
Thank you for reaching us back and I appreciate you bringing this to our attention so that we can deal with this immediately. I understand how this must be inconvenient on your end. Rest assured we will assist you with this until we get the problem sorted out. We don't have any reported known issue about this however, I will check it with the team regarding ATT's phasing out the 3G if it does affect the Arlo Go camera. In the meantime, try to check the KB article below for some troubleshooting steps:
Middle Tennessee is the area. Many people who have these in the area are fed up.
When is this going to be fixed?
"We don't have any reported known issue about this"
Really, that was their response? Either that rep is brand new and didn't check with anyone or is being disingenuous.
I've seen the discussion both here and on AT&Ts forums. It is a known problem.
What I've not seen is anyone saying "Mine are working normally".
So, anyone out there NOT experiencing problems?
T-Mobile with Reolink has been awesome.
My Arlo cameras are going in the trash.
My case # is: 42957129. I really can’t afford new cameras and need these to be reliable for animal rescue. So frustrating.
I have been assigned a contact her name is Gen.
I haven’t send logs to them multiple times.
Thank you for your patience while we navigate this issue with intermittent connectivity. We are working closely with AT&T to identify and resolve the issue as soon as possible. I will provide further updates as soon as possible.
Regards,
Arlo Team
Much appreciated, Shayne. Think you can share a little more about it? Do the teams at least know what the issue is? Related to the 3G phaseout? Thanks for the help.
Same issue as everyone else
My case number is 42968910
Modes et règles
