  • 6 Replies
  • 3015 Views
egilso
Hi!
Since this summer, camera has been disconnecting. It goes offline,but comes back again,being only able to see battery status. It shows massive drainage.
A reset fixes the problem. The problem has also resolved itself after several days.
Right now the camera is again disconnected. When it comes online and I tryto activate video, it goes offline and the spotlight turns on. That's what is draining the battery.
I have opened a case nr 00651484.
My other 3 cameras do not show this behaviour.
6 REPLIES 6
@egilso wrote:
Hi!
Have you tried swapping the camera with one of the other three?  Then see if the issue moves with the camera [or not].
egilso
The camera in question is 4m from the router. It was installed in september 2023 and has not had this behaviour until this summer.
Note that there is a wifi connection, as battery status is reported.
BrookeN
Are you still seeing this same behavior?
egilso
Hi! After firmware update, issues still exist. It still fails to give video, but I can restart it from app, and if I am lucky, I get video for a while. It is not suitable for surveillance that way .
BrookeN
I apologize for the delay in responding. Can you please update me if you are still seeing this behavior?
egilso
Hi! The case is resolved. I will receive a replacement.
