I have 4 x VMC3030 cameras currently. Looking for rechargeables to add, possibly upgrade to VMB5000. Any advice appreciated.
You can have up to a total of 5 cameras while maintaining the free 7 day storage you prob currently have....
I do recommend at least upgrading to a newer base ( at least the 4000 ) if you are going to add Pro / Pro2 cameras.
You can upgrade the cameras one at a time if needed as you switch over.
If you go to the newer cameras, then you will need a subscription after the trial period.
( you can upgrade the base without a subscription )
Yes... the 5000 base will support both older and newer cameras
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
