- English
- Cameras
- Arlo Essential spotlight camera will not record an...
Arlo Essential spotlight camera will not record any video
I have contacted support with no luck. I have done all the steps that they have suggested and no luck. The spotlight will come & I will get a notification that there is motion but it will not record any video. I have it set up to record locally. Even when you use the "live" option there is no icon to click to record or take a picture
Any one have any ideas? I really don't want to buy a new camera as this one isn't even a year old.
@Chrissy1985 wrote:I have contacted support with no luck. I have done all the steps that they have suggested and no luck. The spotlight will come & I will get a notification that there is motion but it will not record any video. I have it set up to record locally. Even when you use the "live" option there is no icon to click to record or take a picture
Did you 3 month trial run out. What you described seems like no subscription with no cloud recordings and no record button when live view.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
