  • 5 Replies
  • 1460 Views
MachPoint9
My Essential XL Spotlight 2032 will not charge any more.  Charges to 24% and then will not respond.  Camera is functional but will not charge.  Any suggestions on how to remedy?
5 REPLIES 5
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
MachPoint9
OK- thanks.  The support prompt says that my camera is not longer in warranty and that support is not longer available....It won' t take me to the support site via the app...
If you have a subscription, then you are entitled to both phone and chat support.
Not sure what you mean when you say it won't take you to the support site.
BrookeN
Can you send a screenshot of what you are seeing? You have a subscription, so support should be offered within the app.
MachPoint9
After leaving it plugged in to charge for several days, I found that at some point it did accept a full charge and is now functioning properly.  Thanks 😊
