Essential camera not recording to USB on VMB4000
  • 13 Replies
  • 3843 Views
  • 5 In Conversation
davem101
I recently bought an Arlo Essential camera.  I want to record locally to USB on my VMB4000 hub, and it won't.  It is connected to the hub.  I've pulled the USB and looked at the files, and none of the recordings are there, and nothing shows up in the app as well.  It does detect motion and send alerts.  Here is the screen on the rules:
All other cameras are working fine and recording locally.
 It even shows that it is defaulting to recording locally.  Any suggestions?
13 REPLIES 13
ShayneS
Do any recordings from you other cameras show on the usb?
davem101
Yes, all of the others do show up.
ShayneS
Can you try rebooting the camera?
davem101
I rebooted both the camera and router.
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
davem101
I appreciate your response and help so far.  I have gone through every troubleshooting step I could find, and researched all the forums.  I'm fairly convinced there is a bug or something or a hardware compatibility issue.   I've rebooted, deleted/reconnected, renamed, updated all firmware, etc.   Formatted the USB (although it's working for all the other cameras).  I have it here in front of me if you need any info.
The fact that it hard codes saving to USB seems to me like it should be working.
What additional info can I provide  you to resolve this?
Storage status
Camera that won't record to usb
Base station 
spring_water
Did you find a fix for this? I have the exact same issue.
ShayneS
@spring_water
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
davem101
No I have not.  I would really like a solution or a refund.  Arlo should publish that these cameras are not compatible.
Right now it's an expensive paperweight sitting on my desk.
If you figure anything out, please let me know as well.
ShayneS
Hi @davem101
I have escalated this to the appropriate team and support will be reaching out to you soon as possible.
Romulodepaula
Any solution about this?
I have a VMB400 base with 3 Pro cameras and this year I bought 3 more cameras from Essencial Spotlight because the website said they were compatible.
When I got home I installed it and the recording of the last 7 days in the cloud from all cameras worked perfectly. Reading about it, I saw that after a period of testing, Arlo no longer records ONLY the Essential Spotlight cameras in the cloud.
How can this be ? It's hard to believe that they are limiting recording to force people to sign up for the service.
I recommended ARLO to several friends and I believe I need to make up for the mistake of doing so.
I await an urgent solution to this imposed limitation.
Not really.
The VMB4000 base supports recording, but it does not support playback.  The ONLY way to see recordings with that base is to eject the storage using the app, and then connect the storage to a PC.  Then browse the PC for the recordings.
Your older Pro cameras were sold with 7 days of free cloud storage.  All the recordings you see in the app or my.arlo.com are coming from the Arlo Cloud - they are not being retrieved from your USB storage.  Arlo stopped offering free cloud storage on new camera models back in 2018, and none of the cameras currently sold have that feature.
A smarthub (VMB4540 or VMB5000) would give you some playback features, but they are limited.
  • recordings only available from the app (not the browser)
  • recordings only available from the primary account (not friend accounts)
  • no ability to make manual recordings or snapshots
  • no thumbnails - recordings need to be downloaded to the phone before viewing
  • remote access requires router setting changes that many find difficult - and which don't work with some internet service providers
Note that if you purchased the new Gen 2 cameras, they are not compatible with any hub yet.  So there is no way to get local storage for those models at the moment.
Romulodepaula
Thank you very much for the quick response.
I understand and do not agree with the adopted policy.
Unfortunately, I will not buy other Arlo products and will look for another solution for my home.
