- English
- Cameras
- Re: Arlo Essential Spotlight Camera Keeps Disappea...
My camera just disappeared from my dashboard last week. I charged and added it back and it worked for a few hours and disappeared again. I charged it as it seemed maybe it wasn't charging as I couldn't get any lights to come on. I added it a second time, it worked and within a few hours disappeared again but before it did I got a message from the app that disappeared.
I have no idea what to do. Is the battery or camera shot? Even after updating firmware the second time why would it disappear and then not reload?
I don't know if I need to change systems or what?
The battery is not replaceable, so there's not much point in figuring out if it's the battery or the electronics.
I suggest moving the camera closer to the router as a test (maybe 6-10 feet away), and see if the behavior changes.
I am having the same exact issue, have you figured it out?
I exhausted everything anyone suggested and still couldn't get it to work.
As I had purchased an extended warranty through Amazon, returned the camera for a refund.
Ok, thankyou!
I've been having the same issue for months. Recently I'll add it back and before I can mount it outside it asks for a factory reset. I'll do it, and then it will ask for it again. I wish I could be more helpful but I think the best thing is to throw it away, or see if you can get your money back.
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
