- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: The 2nd gen option does not appear in the app
I’m in Puerto Rico and I’m trying to connect my 4 new essential outdoor camara and I’m unable to connect because The 2nd gen option does not appear in the app. There is a solution for these
What VPN are you using?
When will the Philippines receive this update?
When will 2nd Gen option be available in South Africa? Its really frustrating that no one is replying to in which countries this is available.
Tengo el mismo problema en Argentina , no puedo conectarla al WIFI , en la aplicación no figura la segunda generación de cámaras , deberían avisar que no esta disponible en determinados países , la compra la hice on line por Amazon y nadie me aviso
Same here. I recently bought 3 essential outdoor cameras (2nd generation) and i can't use them in Argentina!
Hi there, we are in 2025 and there has been no update and region issues to date since 2022. I wish I knew about this before I purchased 2 devices to use in the Caribbean.
wasted my money, this does not work outside of the US, they should place a banner on it so people is aware. What a terrible experience!
Hi James i am in the Philippines and the app don't show the 2nd generation what can I do
Bought a set of 3 outdoor essential XL with button on top. The app doesnot list them. I read everything in ths community amd basically Im dead in the water. I live in Argentina and cannot return the cameras. Arlo never told
of this limitation. I need a solution asap
When will the app be available to the Caribbean region,Grenada to be precise?
I'm having the same problem of not being able to complete set up. The pairing button is on the top of the cameras and not then bottom for the 2nd Gen Essentials system. We are in The Bahamas.
I am having this same issue, I live in Bermuda. When will this be resolved?
El método que utilice en Argentina para pode activar las camara Arlo 2da generación, fue a través de un aplicación , en este caso Surfshark, la cual te permite cambiar el VPN de pais, en este caso lo cambias a EEUU, solamente para poder hacer la programación de las cámaras, cuando el móvil cambia el VPN, te dirigís a programación de Arlo secure, y te aparece las cámaras de 2da generación y podes empezar a programarlas anexándolas al software. Una ves programadas, volves a tu VPN de tu pais de origen y todo funciona genial.
I’m in South Africa and same issue. Is there any news on when we can actually use these cameras?
I live in Bermuda as well. If you have a Us address or a friend has a us address, use that address when setting up, you can then buy an iTunes card and pay the subscription using the iTunes card or your apple account.
Same problem with Arlo 2k 2nd generation. I have seven Arlo cameras and all work well but this new ones don't work in Colombia. I bought my cameras through Amazon and were delivered to colombia but they don't work here. The updated app does not show them when you try to install them What can I do ?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
