- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Introducing Arlo Essential Outdoor Camera - 2n...
Introducing the 2nd generation of the Essential camera, now offered in both 2K and HD options. Experience exceptional smart home security with unbeatable value and price. We all deserve protection, no matter what your budget is or the size of your property. Choose from 2K or HD camera options for round-the-clock protection.
Essential Coverage. Everyday Protection. Essential Outdoor Camera provides smart home security with clear HD 1080P resolution, Color HD Night Vision, and Integrated Siren. Check-in on your home, family or pets anytime.
· First sub $50 HD security camera · Updated seamless Bluetooth onboarding · 130° field of view · Wire-free with built-in rechargeable battery for long lasting battery life · Integrated Spotlight · Color Night Vision · Sleeker form factor with newer battery technology
Essential Coverage. Crystal-Clear Details. Essential Outdoor Camera provides enhanced smart home security with crystal clear 2K resolution and zoom in to see more details without distortion day or night with Color Night Vision.
· First sub $100 2K security camera · Updated seamless Bluetooth onboarding · 130° field of view · Wire-free with built-in rechargeable battery for long lasting battery life · Integrated Spotlight · Color Night Vision · Sleeker form factor with newer battery technology
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Essential Outdoor Camera - 2nd Generation.
Thank you for being part of the Arlo Community!
Apple Home integration is now available for Arlo 2nd Generation devices. For more information on this release, take a look here: https://community.arlo.com/t5/Announcements/Apple-Home-integration-is-now-available-for-Arlo-Essenti...
So I bought one of these today but had no idea I'd run into compatibility problems since my other three devices are all Arlo. App says I need to "upgrade to new app" but then warns that one of my cameras needs a firmware update but no update is available.
So much for plug and play!
I purchased an Arlo Essential Outdoor Camera bundle 2nd Generation last October. However, I have not been able to Install since this type of camera does not appear on your Arlo secure app. Please help. I live in Belize.
Thanks,
Miguel
Unfortunately, these cameras may not have been made available in your region. Also, you can't purchase a plan in your country, making the camera less than useful unless you have a SmartHub to connect it to so you can use local recordings.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
So I can provide a positive update on this. Although there are no firmware updates for one of my older cameras it still works fine for my purposes (motion detect, audio and live viewing) within the updated app.
A live chat with a rep/tech on the Arlo website was extremely helpful in providing this information and taking the time to stay with me while I got things all set up. Bravo!
I have Essential Outdoor camera second generation but I failed to get app any assistance please
Juvens,
Are you able to provide more details about what you're experiencing? Are you seeing an error message or do you have any screenshots of what you're seeing?
Bought 2nd generation wire free doorbell and the picture does not appear in the app althought actualized. So tried all the same with the similar one of round button but when pressing ( after 30 hs and 100% charge and blue light fix ) it does not blink any colour light to make paring.
Can Arlo work well some day with no problem ???????
MarianaLin,
If there is no LED behavior, the battery may be depleted. Try charging the doorbell and then test to see if you still experience the same behavior.
My camera needs to be charged, but I cannot figure out how to get it off its base. There's nothing in the manual about it and I cannot find anything on their website and their little tech bot was absolutely useless in helping me. There's no button by the charge port. The tech bot online told me to turn counterclockwise and I did and it just kept turning and not getting looser or making any sound. How do I take this thing off the port so I can charge it? Very disappointed with their customer service. 🙄
There is a triangle embossed on the base. Slide the camera+base in the direction of the triangle, and it will come off the wall plate. Note that if you followed the mounting instructions, the triangle should be at the top.
Turning the camera (but NOT the base) should detach the camera from the base. Then you can easily see how to slide the base off the wall plate. This does work with my own camera.
there seems to be a problem with the arlo app on the android phone .it stops showing you the number of camera activations when you open up the app . if i open the app on my computer it shows the number of activations up on top on the right next to the settings wheel .For some reason it will not show that on the arlo phone app .I tried uninstalling the app and it works when i install it and open it but when i close it and open it up again later it stops showing me the number of activations on each camera . I called and talked to several customer support people until im blue in the face .These people just don't understand me or how the cameras is suppose to work . 1St of all arlo has to invest in support that can understand people from the usa that speak english and understand how these cameras work and how to fix the issues .I am paying a fee to monitor my cameras and I am also suppose to receive support when there is a problem so arlo better fix this issue and also give me a credit for the problems that i am having
Hi @salamanda2
Thank you for reaching out and sharing your experience. The recording count number displayed on the device thumbnail is currently a feature available on the Arlo web portal at (my.arlo.com) and is not displayed in the Arlo mobile app. This is the current design across both iOS and Android versions of the app.
Great to see the new Arlo Essential Outdoor Camera 2nd Generation launch. The improved video quality, longer battery life, and smart security features make it a strong option for anyone looking to upgrade their home security setup. Looking forward to seeing how it performs in real-world use.
you are soooooooo WRONG , this worked for years and stopped working about a week ago .I think its time to fix this issue . Can anyone there make updates that work ?
it maybe a longer life battery but it still doesn't last unless your charging it all the time
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
