Introducing the 2nd generation of the Essential camera, now offered in both 2K and HD options. Experience exceptional smart home security with unbeatable value and price. We all deserve protection, no matter what your budget is or the size of your property. Choose from 2K or HD camera options for round-the-clock protection.
Essential Coverage. Everyday Protection. Essential Outdoor Camera provides smart home security with clear HD 1080P resolution, Color HD Night Vision, and Integrated Siren. Check-in on your home, family or pets anytime.
·        First sub $50 HD security camera
·        Updated seamless Bluetooth onboarding
·        130° field of view
·        Wire-free with built-in rechargeable battery for long lasting battery life
·        Integrated Spotlight
·        Color Night Vision
·        Sleeker form factor with newer battery technology
Essential Coverage. Crystal-Clear Details. Essential Outdoor Camera provides enhanced smart home security with crystal clear 2K resolution and zoom in to see more details without distortion day or night with Color Night Vision.
·        First sub $100 2K security camera
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Essential Outdoor Camera - 2nd Generation.
Thank you for being part of the Arlo Community!
185 REPLIES 185
Apple Home integration is now available for Arlo 2nd Generation devices. For more information on this release, take a look here: https://community.arlo.com/t5/Announcements/Apple-Home-integration-is-now-available-for-Arlo-Essenti...
Greg_Midi
So I bought one of these today but had no idea I'd run into compatibility problems since my other three devices are all Arlo. App says I need to "upgrade to new app" but then warns that one of my cameras needs a firmware update but no update is available.
So much for plug and play!
MGONGORA1
I purchased an Arlo Essential Outdoor Camera bundle 2nd Generation last October. However, I have not been able to Install since this type of camera does not appear on your Arlo secure app. Please help. I live in Belize.
Thanks,
Miguel
Unfortunately, these cameras may not have been made available in your region. Also, you can't purchase a plan in your country, making the camera less than useful unless you have a SmartHub to connect it to so you can use local recordings.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
Greg_Midi
So I can provide a positive update on this. Although there are no firmware updates for one of my older cameras it still works fine for my purposes (motion detect, audio and live viewing) within the updated app.
A live chat with a rep/tech on the Arlo website was extremely helpful in providing this information and taking the time to stay with me while I got things all set up. Bravo!
Juvens
I have Essential Outdoor camera second generation but I failed to get app any assistance please
Juvens,
Are you able to provide more details about what you're experiencing? Are you seeing an error message or do you have any screenshots of what you're seeing?
MarianaLin
Bought 2nd generation wire free doorbell and the picture does not appear in the app althought actualized. So tried all the same with the similar one of round button but when pressing ( after 30 hs and 100% charge and blue light fix ) it does not blink any colour light to make paring.
Can Arlo work well some day with no problem ???????
MarianaLin,
If there is no LED behavior, the battery may be depleted. Try charging the doorbell and then test to see if you still experience the same behavior.
g1alelo
My camera needs to be charged, but I cannot figure out how to get it off its base. There's nothing in the manual about it and I cannot find anything on their website and their little tech bot was absolutely useless in helping me. There's no button by the charge port. The tech bot online told me to turn counterclockwise and I did and it just kept turning and not getting looser or making any sound. How do I take this thing off the port so I can charge it? Very disappointed with their customer service. 🙄
There is a triangle embossed on the base.  Slide the camera+base in the direction of the triangle, and it will come off the wall plate.  Note that if you followed the mounting instructions, the triangle should be at the top.
Turning the camera (but NOT the base) should detach the camera from the base.  Then you can easily see how to slide the base off the wall plate.  This does work with my own camera.
