bought 3 Arlo essential gen 2, and brought them to Costa Rica, however when I try to do the initial set up I can get them to recognize the QR in my iPhone so I can’t connect them to my phone… could this be a region issue???
@jguerdat wrote:
I don't believe it would be a region issue. Try resetting them:
Not sure why you are ruling that out. Arlo doesn't offer subscriptions in Costa Rica (or any other country in Central or South America)
@Kevin8435 - when you go into "add device" are you seeing the Essential Gen 2 option? Or are you just seeing Essential and Essential Spotlight?
If you can choose the specific camera model, you can onboard them. That's the only restriction until you try to get a subscription.
already did and still not working
I do not get the gen 2 option no
im only getting the essential indoor, essential and essential spotlight, no gen 2
That's the problem. No idea when it will be added.
Though obviously not something Arlo likes, it is possible to create an account using a VPN that terminates in the US. That would get you the ability to add the camera. You'd only use the VPN to create the account - you'd turn it off when onboarding the camera.
Getting a subscription for that account would also be possible if you have a US payment method.
Well I don’t really know how to get a vpn for the US… if you have any instructions that would be great
Plenty of options, some are here:
Generally you can just where you want the VPN terminated - US is one of many possibilities.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
