  • 9 Replies
  • 1832 Views
Kevin8435
bought 3 Arlo essential gen 2, and brought them to Costa Rica, however when I try to do the initial set up I can get them to recognize the QR in my iPhone so I can’t connect them to my phone… could this be a region issue???
9 REPLIES 9
I don't believe it would be a region issue. Try resetting them:
https://kb.arlo.com/000063225
Not sure why you are ruling that out.  Arlo doesn't offer subscriptions in Costa Rica (or any other country in Central or South America)
@Kevin8435 - when you go into "add device" are you seeing the Essential Gen 2 option?  Or are you just seeing Essential and Essential Spotlight?
If you can choose the specific camera model, you can onboard them. That's the only restriction until you try to get a subscription.
Kevin8435
already did and still not working
Kevin8435
I do not get the gen 2 option no
Kevin8435
im only getting the essential indoor, essential and essential spotlight, no gen 2
That's the problem.  No idea when it will be added.
Though obviously not something Arlo likes, it is possible to create an account using a VPN that terminates in the US.  That would get you the ability to add the camera.  You'd only use the VPN to create the account - you'd turn it off when onboarding the camera.
Getting a subscription for that account would also be possible if you have a US payment method.
Kevin8435
Well I don’t really know how to get a vpn for the US… if you have any instructions that would be great
Plenty of options, some are here:
Generally you can just where you want the VPN terminated - US is one of many possibilities.
