- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Arlo Essential XL Spotlight won’t take a charge
I disconnected the camera from the network because it was entirely unresponsive and wouldn’t charge.
I plug in the camera, no blue light. The infrared turn on briefly. There is a clicking noise in the camera like it is recording.
I hold down the button, no response. Wait ten seconds, no response. Wait one minute, no response.
the camera has turned into a paperweight.
Cannot reset. Cannot connect.
Please help.
I am experiencing the same issue with two of them. Only been in use since June 2024.
My issue has escalated through technical and I await a response.
It’s good to hear I’m not the only one. If you don’t mind, would you share whatever solution they give you when you get it?
roachroach,
The symptoms you described could indicate a hardware related issue. I encourage you to reach out to the support team and open a ticket detailing these symptoms by using the Arlo app under Settings > Support.
Unfortunately, since I had removed the device to try and reboot, there is no device connected to reference for the support request.
Arlo have now confirmed replacements for both cameras as they are faulty. They only worked between June and August 2024
I guess I need to do something similar, cause it surely
hasnt fixed itself.
Arlo Support, holler at me. I can’t submit a claim.
roachroach,
If you have a subscription plan, you should be able to open a support ticket under Settings > Support. Once the ticket is open you can reference the serial number for the device that is experiencing issues. Please let me know if you need further assistance.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
