IAMSAMMICH
Updated to the newest iOS app with the refreshed interface and both my wife and I are unable to hear audio on our baby monitor now. Please fix ASAP.
298 REPLIES 298
cassfan3
I'm beginning to think these software designers are incompetent. Is nothing Beta tested? Now our Arlo baby has no sound - thus is worthless as a baby monitor. What a joke.
Jakovacn
Same here. No sound on either my iPhone or iPads since the new IOS update . This is worrying. 😞
ChrisKalna
Everyone, check your apps. Mine just randomly started working. Noise can be heard again. I made no other changes.
ChrisKalna
Check again. Mine just started working. I made no other changes.
Bahubaali
I tried again, after restarting app and phone. Audio still does not work.
JerzeyMike
It worked, thanks!!! Very annoying, but glad to have sound again!
ChrisKalna
Check your apps. Mine just started working again. No word from Arlo or Netgear and I did nothing different. Just opened it and it was working.
Alexl1118
It has to do with your Wifi network. If you disconnect from your network and use your cellular network the sound works again.
Alexl1118
I disconnected from my WiFi network today and can now listen to the audio. You have to use cellular network. Obviously obnoxious but it’s a workaround until netgear fixes the app.
irinaB
Yeap. Disconnect from wifi and connect on mobile, then connect on wifi. Works
Retired_Member
Not applicable
In response to various: indeed the snippets work as a stop gap but still not impressed with lack of fix from Arlo.
Also, yep, as per other posts: it’s definitely an iOS thing. Sound works on desktop through our MacBook Air.
ARLO: PLEASE GET ON WITH IT AND FIX!
Retired_Member
Not applicable
Tried and didn’t work for me 😞 thanks for the tip though...
ChrisKalna
Update - nope! Just kidding. Still does not work. It will work if you're not on Wifi, which is just as useless and annoying.
ChrisKalna
Yeah, as it turns out still does not work. I disconnected from wifi and used cellular only. That does work. Reconnecting to wifi just starts the trouble again.
Megahurtz
Confirmed its a bug with new update, ipad with the old version still has sound for the baby came, iphone and ipad with the new version doesnt have sound.  Android with the new version has sound so it seems like an IOS only issue.
kingcobr4
Found a solution but only for Apple users. You can open the camera in the Home App and still have access to sound. You may not get the temperature features but this is a work around until Netgear fixes this problem. It’s truly unfortunate that they can send out an update that would do something so terrible but for now this should help a few people get some peace of mind.
emilyl
What is the home app?
kingcobr4
The Home app is for the Apple HomeKit. It allows you to control all of your smart devices and see your Arlo cam in one place instead of using multiple apps. You can get it from the App Store and connect it in the Arlo settings underneath HomeKit. But this only works for Apple products
Eflo14
Since updating to the newest app version 2.6, I have been having connection issues with my Arlo Baby Monitor. It does not stay connected and is constantly having a “connecting” status. I have done a full factory reset on my camera as well as going back through the reinstall. Nothing seems to help the problem. Is there a sort of update to fix these issues? This is a real hazard not to have this for my baby.
Staceylm1
has Anyone spoken to support and have they given an idea of when this will be fixed?
GooberUber
It’s working just fine now. appears they had some server side issues as there weren’t any client side changes
LittleGiant43
I tried using the home app yesterday and it was working fine, but then something happened and I wasn’t able to view the feed. It says the camera is not available because someone else is using it, but that is not the case. Going to try removing the camera from “my home” and then reconnecting.
escy
Having the exact same problem...since the app update. Continuously says connecting but it doesn't! Please fix ASAP!
JAndST
Ours is still not working
GooberUber
Accidentally discovered another edge to the bug.. If you disable your WiFi on your phone, for instance, and connect over LTE/mobile network, you’ll get audio. If you’re on the same WiFi network, it does not work. This tells me that the WiFi based audio transmission is likely the problem. If you can handle the data transfer cost, just drop into LTE and monitor that way.
