Re: 2.6.0 iOS update renders Arlo Baby worthless
- Email to a Friend
I'm beginning to think these software designers are incompetent. Is nothing Beta tested? Now our Arlo baby has no sound - thus is worthless as a baby monitor. What a joke.
- Email to a Friend
- Email to a Friend
Everyone, check your apps. Mine just randomly started working. Noise can be heard again. I made no other changes.
- Email to a Friend
Check again. Mine just started working. I made no other changes.
- Email to a Friend
- Email to a Friend
- Email to a Friend
Check your apps. Mine just started working again. No word from Arlo or Netgear and I did nothing different. Just opened it and it was working.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Also, yep, as per other posts: it’s definitely an iOS thing. Sound works on desktop through our MacBook Air.
ARLO: PLEASE GET ON WITH IT AND FIX!
- Email to a Friend
- Email to a Friend
Update - nope! Just kidding. Still does not work. It will work if you're not on Wifi, which is just as useless and annoying.
- Email to a Friend
Yeah, as it turns out still does not work. I disconnected from wifi and used cellular only. That does work. Reconnecting to wifi just starts the trouble again.
- Email to a Friend
Confirmed its a bug with new update, ipad with the old version still has sound for the baby came, iphone and ipad with the new version doesnt have sound. Android with the new version has sound so it seems like an IOS only issue.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Since updating to the newest app version 2.6, I have been having connection issues with my Arlo Baby Monitor. It does not stay connected and is constantly having a “connecting” status. I have done a full factory reset on my camera as well as going back through the reinstall. Nothing seems to help the problem. Is there a sort of update to fix these issues? This is a real hazard not to have this for my baby.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Having the exact same problem...since the app update. Continuously says connecting but it doesn't! Please fix ASAP!
- Email to a Friend
- Email to a Friend
Arlo Baby
