Arlo Door Bell - Hourly Motion Detection
For some reason my door bell indicates motion at an hourly pace. It seems to be very consistent in the spacing of time even though I have never seen any motion associated with the event on the triggered camera. The triggered camera is not within the motion area for the door bell.
For example today. I received motion indication at 7:13, 9:13, 10:13, 11:13, 1:13, 2:14. It never goes 24 hours a day, but will be in sequences like this. I am not really seeing any settings related to this issue. Any idea of what is going on?
I have the same thing going on. I turned off the doorbell recordings and use only the camera to detect and record.
If others out there have this going on (the doorbell is causing hourly recordings) Please post here and open acase with support:
My Arlo doorbell regularly (every 1,2,3 or 4 hours) triggers from supposed detected motion and alerts me and perfoms recording. See the image of 4 days of such recordings. There is no real motion - the trigger is sourced in the cloud service I believe as the regularity (nearly on the hour or +61 minutes) is too regular; there is no motion in the recording. Nothing is this periodic in a naturally chaotic environment - lest it be that the trigger is being caused from some probing WiFi or something which is impacting the doorbell. 2.4GHz is surely noisy here. What's the reason and what's the solution? I don't like being alerted falsely so often of course.
I also get hourly recordings due to the doorbell. I turned off the setting in the doorbell to detect and record and use only the camera detection to record -works fine.
Open a case with support:
My doorbell does this too - a dozen or more false motion detections per day, usually hourly following an actual detection. I chatted with support today who had me reset and re-add my doorbell - it is still happening. I'm not convinced Arlo recognizes this as a problem yet.
Had a chat session with afloat today and they entered a ticket on the issue. I was not where I could access the door bell today, but will get back with them Wen I can. I had three false motions today 12:12,1:12 and 2:12. Thirteen of them yesterday. Since I have a camera assigned toot is just eating up the batteries.
Same issue with me. Hourly false alarms... I put the camera in an unused room as they requested and the same thing. I have an open case and no progress thus far
They have closed my case on the issue since I was unable to perform a reset on the door bell while I was out of town. Hopefully yours will come to a resolution.
Re-open your case with a new one that references the old. In the future, reply to the case every couple of days so it doesn't auto-close.
I am currently going through the same support motions - have reset the doorbell, changed to a different linked camera, and now have the doorbell off the door and facing a wall to see if it still triggers. Hopefully they are collating all of these cases and moving towards a solution.
I’ve had the same problem too. Many false alarms. They replaced my old doorbell with a new one but I’m seeing same issue with new one. I don’t see the false alarm every hour but if a couple hours go by then all of a sudden I get another false one it’s at the same minute of the hour. For example today I had false alarms at 6:11am, 11:11am and 12:11pm. I’m about to give up on this thing
I just turned off the doorbell triggering the recording and let the camera do its own thing through normal modes and rules.
Performed the resync procedure Saturday and as of today (Tuesday) I have not received a false alarm.
You have to remove the doorbell, but do not remove the batteries. In the center below the batteries is a sync button. Press and hold this until it starts to flash then reinstall and retest.
Update: Level 2 support sent a replacement doorbell, no improvement. I asked if something had been found when they sent the replacement - got the distinct impression that this is just the next thing they try. I have no confidence that anyone on the product development team is involved in this “investigation”.
This doorbell design clearly has a systemic problem, and I don’t see anywhere that Arlo has acknowledged this fact.
Doing the Resynch or reset button on the back of the unit and then re-adding the doorbell as new did not help me. Eventually it starts giving false alarms again. Level 2 support has all of my information and I’m waiting for an answer
Another new issue I noticed in the past few days is that once you turn on motion detection for the doorbell you then can’t turn it off. Once I click the check mark for “Motion Trigger Alerts” I cant go back in and turn that off. This is true in iOS app and when using the browser based access.
Can't speak for iOS but it works fine on Android. The web has always been unable to do anything with that checkbox.
Pretty funny. I just tried Android and I see what you mean. Yes. The app in an Android will turn off motion for the doorbell and so it works Ok. But. It’s still not working in iOS (my iPhone or iPad) and it doesn’t work in browser. There’s definetly a bug.
I received an RMA for my doorbell, but based on your experience with the replacment, i may just not even bother sending it back... I finally gave up and used the motion detection of the camera.
They are saying to perform a resync. I that that solved my problem, but it appears to have lost sync so I was not getting the false alarms. Will try to resync it again and see if that resolves it.
Yes. You would need to delete your doorbell and then re-add it as a new doorbell once you press and hold that resynch button. But. I’ve done that multiple times myself and it hasn’t fixed anything.
