I have 2 Chimes (HW Version1.2 and Firmware1.2.0.0_297_266) and they constantly get out of Sync.
They are installed not more than 10 meters from the Arlo Ultra base.
The question is: why do they get out of Sync all the time
You can try and reposition the base station a bit higher and see if that helps with the signal. it sounds like there may be some interference or range issue with walls etc.
Hi @MDNZ
I have attached an article that you can utilize to help extend your systems range. How can I extend the range of my Arlo system?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Reset base
Relocated chimes
Relocated base
Thank you for the info. To help expedite the process, I would suggest contacting Customer Support and inform them of your current issue. I have attached the link here for you - Arlo Tech Support
