  • 8 Replies
  • 4040 Views
KevinGlennon
I have 2 Chimes (HW Version1.2 and Firmware1.2.0.0_297_266) and they constantly get out of Sync.
They are installed not more than 10 meters from the Arlo Ultra base.
The question is: why do they get out of Sync all the time
8 REPLIES 8
ShayneS
Hi @KevinGlennon
You can try and reposition the base station a bit higher and see if that helps with the signal. it sounds like there may be some interference or range issue with walls etc.
MDNZ
Is the communication between chime and the base station using its own wifi or the existing home Wireless network. Is there anyway to extend the wifi coverage for an Ultra base
ShayneS
Hi @MDNZ
I have attached an article that you can utilize to help extend your systems range.  How can I extend the range of my Arlo system?
MDNZ
Thanks Shayne however I had already read that and it does not mention how you can extend the wireless range of an ultra base station. It mentions how you can reposition your base station but no bridge or extension. Is there any way to extend
KevinGlennon
I have already moved the base twice. No imprvment
ShayneS
@KevinGlennon
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
KevinGlennon
Reset chimes
Reset base
Relocated chimes
Relocated base
ShayneS
@KevinGlennon
Thank you for the info. To help expedite the process, I would suggest contacting Customer Support and inform them of your current issue. I have attached the link here for you - Arlo Tech Support
  • 8 Replies
  • 4041 Views
