- English
- Arlo Forum Discussions
- Partner Integrations
- Re: tinyCam Android app now fully supports Arlo ca...
Hi,
I'm the developer behind tinyCam Android app. Last month Arlo support was added into tinyCam Monitor app. It supports live view for all cameras like Arlo, Arlo Ultra, Arlo Pro, Arlo Pro 2, Arlo Pro 3, Arlo Q, Arlo Go, Arlo Baby, Arlo Video DoorBell and allows playback Arlo Cloud recordings in the app.
It greatly increase the way your Arlo camera can be used with following unique features:
- Video recording (local storage, time-lapse, FTP/FTPS, Dropbox, Google Drive, Microsoft OneDrive, ownCloud, Nextcloud).
- RTMP live streaming. You can stream your Arlo camera to Twitch.tv, Youtube Live, Facebook Live.
- A.I. object detection (person, pet, car) and face detection.
- Background/DVR mode (background recording and background motion detection). Not suitable for battery powered Arlo cameras though.
- Native TV UI (Android TV, Amazon Fire TV).
- Internal web server for remote recordings playback and live view. You can make Arlo cameras integration with home automation dashboards like Action Tiles.
- Widgets right on home Android screen.
- Up to 4 floating windows and picture-in-picture mode.
- Android Wear app. You can view Arlo camera on your Android Wear watches.
- Google Cast support. Show live view on any Google Cast device, like Android TV.
- Full Tasker integration.
Available on both Google Play Store and Amazon Appstore
Samsung SmartThings
Just tested it here and only my Q camera will stream. I tried adding a camera to see if that helped but - nope. @alexvas
Everyone should use the tinyCAM app settings, choose Developer Options at the bottom and view the logs. At the bottom is a Send selection - use that to email the logs to @alexvas
Arlo moved to new servers. Now tinyCam does not work . Working on the fix.
Ha! The beta (4.3.3 beta 1) works fine.
Video for Arlo cameras should work in tinyCam 14.3.3 Beta available in Google Play beta channel.
Also Arlo Doorbell support has been added as well.
You can signup for beta testing here https://play.google.com/apps/testing/com.alexvas.dvr.pro
When entering the Audio Settings within the camera settings, an error fades onto the bottom of the screen “Audio is not available for tour camera.“
Audio is not available at the moment for Arlo. Will be added later.
When I attempt to change the channel selection (in order to choose a different camera) it will not allow it, i.e. the channel can not be modified.
I tried what you said, and I got a ¨Current authentication is not completed¨ Error 1187 message.
Any idea of how to fix that?
You are using tinyCam 14.3 right (check app drawer upper left corner)? The issue is fixed in tinyCam 14.4 which will be available for download within a couple days.
tinyCam 14.4 brings Arlo 2FA support and Arlo cloud view as timeline. Enjoy!
tinyCam 14.5 brings 1-w audio support for all Arlo cameras.
SOLVED When adding my login info for tinycam it the ask for my 2FA passcode but Im not getting anything sent to my email or text like selected under my 2FA setting in the arlo app. Anyone else having this issue or have a work around this?
@Chatydadi Could you contact me (tinyCam dev) by app support email for troubleshooting?
Please contact tinyCam app developer by email for troubleshooting.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
