Thank you
Can you push a reset HomeKit token to mine also
Sure thing @SCOOOP
Thank you
Trying to reset my VMB4500 base station but it is not discoverable by Homekit.
Can I get the token reset please?
While waiting, I was able to get Ro from the chat line to reset my token. Thanks anyway
Thanks for the update!
I have same problem Could you do for me too?
SJAvocado,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I’m Trying to reset my VMB4500 base station but it is not discoverable by Homekit. The virtual chat isn’t being useful
I entered the wrong product. My product is VMC4030. Does this request still work or do I need to go to a different form
Actually the token reset is for the base. The mods will get back to you if they have trouble figuring out what to reset.
Ah good point. Thanks. Read the wrong spot. Hopefully they can reset it!
Blee123,
That worked. Thank you so much!
Please, I also need a reset of HomeKit token for my VMB4500.
Kindly
Mikael
Brilliant, now it works!
Hi, can I also request a token reset for my base station? Thanks!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hi
Can i have my token reset as well?
Hello, can you please reset my token as well?
Please push token
AppleTV
32 -
Samsung SmartThings
84 -
Security System
