- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 token reset needed for Apple HomeKit
noticed several previous reset request, pretty sure what i need
i have 2 base station, newer station 4500 all OK with Apple HomeKit.
but VMB4000r3 not responding , firmware is latest per app, SN
![](/skins/images/0B0081734B366306C47D59D51022AC5B/responsive_peak/images/icon_anonymous_message.png)
i need a token reset
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
How do I connect my Arlo device to Apple HomeKit?
May I also request a reset token for my base station?
It appears the basestation is offline. I can not reset the token until it is online. Please update me when it goes online.
Good evening,
I've been trying to connect my VMB5000 Hub to my Apple HomeKit app. May someone help me please?
Thank you in advance.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
I need a reset token to my base station again, it will work then stop working so I factory reset it to try again hopefully this helps
I had some issues and I reset my base station VMB4000r3 and now it won’t work, just says “searching for my device” when I try to reconnect to my HomeKit. Can I please get a token reset? Last 4 of S/N 9B9E
need a reset token again because when trying to add to Apple HomeKit it just keeps looking for devices but never finds my base station
@Toxiicscorpiio8 I answered the dm you had sent to me.
Can you send me a reset token please?
Hi can I get a reset token for my base station? Not discoverable by HomeKit. On the same network and up to date.
@MDS006 I know, thank you though.
I need token reset.
Thank you
Hello, good night get a token reset for Apple HomeKit integration
I need another reset token as my Apple HomeKit doesn’t work again
:How do I connect my Arlo device to Apple HomeKit?
Thank you. HomeKit was visible in the Arlo app but would not connect to the base station. I did several retries. Now HomeKit isn’t visible in Arlo. Arlo just says searching.
AppleTV
28 -
Samsung SmartThings
76 -
Security System
