- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 token reset needed for Apple HomeKit
noticed several previous reset request, pretty sure what i need
i have 2 base station, newer station 4500 all OK with Apple HomeKit.
but VMB4000r3 not responding , firmware is latest per app, SN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
all good now with 2 stations with total 24 cams in Apple HomeKit on iPhone & Apple TV.
I need a token reset
@btnorton3 you have a few basestations on your account. Can you dm me which one you are wanting the reset for or do you want them for all of them?
Please reset the VMB4540r3 serial number ending in 08DA
Can I get a token reset please?
TIA
Thank you
Can you reset my base station please ?
Can i have a reset as well
I have the same issue
VMB4000r3 with two Pro 2 and can’t connect with appl HomeKit. I also have two Pro5s that can’t connect to home kit or the VMB4000r3. Os/ firmware all up to date.
Hi, I also need a token reset, thanks!
Hi, I’m somehow still unable to add the device to HomeKit.
In the app, it states Discovering your device, please wait. I have tried multiple reboots.
your a rat LOL
do you not think its odd all these acounts ask for a token reset for the same base stations?
Can I get a reset token to my base station 😞
i need a token reset to my base station i think someone is hacking my acount
why is your base station down so much?
AppleTV
31 -
Samsung SmartThings
81 -
Security System
