My Arlo has stopped communicating with Apple Home. I've deleted the integration (Bridge), but I'm having issues re-creating the integration. My Arlo app is stuck at Discovering your device.
I’ve updated the app, updated the IOS, and restarted the base device. It appears that I need the token reset for HomeKit. Can anyone please help?
The token has been reset, you will need to reboot the smarthub/base station.
Thank you!!
Can you please reset my token ?
4R058A7VA7186
@Retired_Member your token has been reset. You will need to reboot the smarthub/base station.
I’ve rebooted a couple times and no luck. Is there a way to get the setup code and j can add it directly in HomeKit? Or do I need to factory reset the base station?
Reboot your devices and try removing and reinstalling the Arlo app.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
