  • 6 Replies
  • 3453 Views
2talltexan
My Arlo has stopped communicating with Apple Home.  I've deleted the integration (Bridge), but I'm having issues re-creating the integration.  My Arlo app is stuck at Discovering your device.
I’ve updated the app, updated the IOS, and restarted the base device. It appears that I need the token reset for HomeKit.  Can anyone please help?
BrookeN
The token has been reset, you will need to reboot the smarthub/base station.
6 REPLIES 6
BrookeN
2talltexan
Thank you!!
Retired_Member
Not applicable
Can you please reset my token ?
4R058A7VA7186
BrookeN
@Retired_Member  your token has been reset. You will need to reboot the smarthub/base station.
Retired_Member
Not applicable
I’ve rebooted a couple times and no luck. Is there a way to get the setup code and j can add it directly in HomeKit? Or do I need to factory reset the base station?
BrookeN
Reboot your devices and try removing and reinstalling the Arlo app.
