- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo pro 2 VMB4500 activate siren through IFTT...
Hi,
I Have one base (VMB4000) On that one I can activate the siren through IFTTT.
And on my other base (VMB4500) it's not possible to do that, the base won't show up in the recipe, why is that?
This is VMB4500 base.
I have VMB4500 base station with arlo pro 2 cameras. I can't get ifttt to record. I have read that a firmware update for VMB4000 solved this for many of you. Any suggestions for VMB4500?
This is the VMB4000 base
Hi Tranceblast,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Let me reach out to you via private message to gather more information from you.
"As I understand your are facing some issue regarding Siren on your base station (VMB4500) throught IFTTT.
Unfortunately we no longer support IFTTT.
Please, contact IFTTT Support"
Seriously?!
Hi Tranceblast,
We wanted to let you know that we still support IFTTT. Let me reach out to you via private message to gather more information in regards to your post.
The development team is investigating reports of this issue where you are unable to see the VMB4500 to activate the siren on IFTTT. We will provide an update as soon as we hear any new information.
(UPDATE: 7/19/2020 - You should be now able to see the VMB4500 available to activate the siren on IFTTT. If you still don't see this option, please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.)
The siren on the VMB4500 is pretty pathetic (only 90dB rather than the 100dB VMB4000 that was promised by the Amazon listing) but not being able to control it through IFTTT adds another level of frustration.
I assume this relates to teething troubles with the new model; do you have any idea when the IFTTT siren integration will be fixed?
AppleTV
31 -
Samsung SmartThings
81 -
Security System
