  • 17 Replies
  • 16111 Views
  • 8 In Conversation
amyglen
My Arlo Pro Station stopped working with Apple HomeKit. I removed it and am trying to re-add it, but I keep getting stuck at "Discovering devices ...". Could I have a token reset? Thanks!
JessicaP
Hi amyglen, bcmacman, Fellini, QuintusPre, IgnacioMZ, abd Sbalgobin,
I've sent a token reset request to your Base Station that should resolve the issue. Please reboot your Base Station (remove and reapply power) and allow the Base Station to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
17 REPLIES 17
bcmacman
I need a token reset for HomeKit as well.  Do not have code to add Basestation to HomeKit.
Firmware 1.17.0.0_3953_6ba79e5
Hardware VMB4000r3
IOS  15.2.1
Fellini
I bought a SmartHub to connect my Arlo Pro 4 cameras to Apple HomeKit but when I try to configurate the HomeKit it's just spinning around, not getting any further. I've read the other threads about this and the problems seems to be solved using a token. I've tried all the other suggestions.
VMB4540
A731147XA14F4
A41162DB2EAF
QuintusPre
Luminary
Luminary
Can you send a reset token to my Home hub VMB4000 so I can reconnect to HomeKit? Thanks!
IgnacioMZ
Same problem... can you help us by resetting the token?
Sbalgobin
JessicaP
bcmacman
Thank-you, however HomeKit sees Arlo hub but even after Hub reset, still asks for a 8 digit Setup Code.  There is no code on hub, where do I get it?
JessicaP
Try to set up your Arlo system for Apple HomeKit through the Arlo app (refer to "To setup an Arlo camera without a setup code" on the linked article) and not through the Apple Home app.
bcmacman
QuintusPre
Luminary
Luminary
Solved! Called support and they sent a reset token. Thanks. Not sure why this is necessary but I’m now up and running.
@bcmacman wrote:
What base model do you have?
FWIW, I am seeing the HomeKit option on my iPhone 12 mini.
bcmacman
VMB 4000
iPhone 13 Pro Max
amyglen
Was the Arlo Pro base station added to HomeKit already? If so, try removing it from the Home app first ...
bcmacman
Have done that.....still no Homekit option.
bcmacman
No base station in Homekit
JessicaP
Hey bcmacman,
Make sure you have "Home Data" permission enabled for the Arlo app. You can do this by going to your iPhone Settings > Arlo > Toggle "Home Data" On.
Then go to the Arlo app and you should see HomeKit for your device and try setting it up from there.
bcmacman
That did it!!  Thank-you.
